Make darn sure your thermostat is working and has not soft failed. The 1.8t are known for oil pick up clogging with carbon like deposits, not sludge as we know it.
You cannot relay on the ECU to warn you of thermostat failures, you can only verify this by a scan tool that reads real time data. These cars should run 200-205F when fully warmed up in the colder Winter temps.
Do not fall into the trap that the only thing that you need to worry about is the temp sensors in these car.
Also if you have an automatic transmission it will also appreciate a properly operation thermostat as well.
What I would be worried about is cooking off excess moisture and fuel in the crankcase. Even if you drive on the weekends, if the engine is running too cold, you may not get the oil and crankcase up to temperature.
Trust me on this, the springs start to weaken on thermostats and I do not trust most of them after about 4 years. I have seen some designed have a hard time lasting 2 years.
