1 - 1 of 1 Posts
Have a 2006 New Beetle Convert. (Automatic) We want to tow it behind our Motor Home on an EZE Tow (Acme) tow dolly. This dolly does not use a pivot plate so the car must be left in PARK with the steering wheel unlocked.
Therein lies the issue. Since this would leave power on. What is the proper procedure?
Use a "Memory Saver" plugged into the Cig. Lighter and disconnect the battery? Will this cause Throttle body set issues?
Just Disconnect the battery and all will be ok upon re connection?
If Battery is disconnected I would assume it must be done after closing the doors due to Auto window drop and rise.
Any other ideas / suggestions are appreciated.
Thanks in advance
1 - 1 of 1 Posts
