1999 Beetle TDI
following along..mine has the same symptoms as well...
90% chance someone has been inside the door, likely to replace the door lath, and they did not both pre-load the door latch properly and also reassemble the door handle parts correctly.
This could be a good reason. Car was repainted in a VW shop, and they didn't do a good job. And I bet they reassemble the door handle wrongly!
The door handle is not too difficult if you know what to do and what to look for, however, there are A LOT of things that can go wrong.
There is a special spring to preload the door handle pull that is rather genius but most people will miss this.
There is also a bracket that locks things into the door that often does not get installed correctly.
Also the door is difficult to get into for most people and they also break a plastic door latch support that should be readily available at the dealer but is usually special order along with a pop rivet that is the wrong one, it need to be trimmed on 2 sides because the head is too big.
Trust me, I can take these doors apart blind and put them back together properly standing on my head.
But is not easy to explain and the are actually a bit easier than the coupes as far as I am concerned due to the way the window regulators are installed.
See this link - http://newbeetle.org/forums/929706-post4.html
