Good Morning
2000 Beetle tdi.
Does anyone have the electrical schematic or diagram for the plug that operates the electric door locks drivers side? It will not lock or unlock with the remote. I switched the door lock assembly and still does not operate. The passenger side operates fine so am wondering if in the plug. Does anyone know which wire is which and I can test the wires with a meter?
Thanks
Pam
The cable that operates the door lock goes from the 29 pin connector on the control module that is part of the power window motor to the 8 pin connector on the latch assembly. From the control module on the communications is done by serial bus so if the windows and mirrors are working properly the bus is probably good. The easiest way to diagnose the problem would be to use a VW-specific scan tool. Chances are an error code is stored that will point you to the problem.
Ross-Tech: Products
