1 - 1 of 1 Posts
First post after researching problems with my daughter's 2000 Beetle.
The power locks didn't always work and the headlight reminder chime didn't at all.
I replaced the doom lock module and now everything works great except...
When you pull the inside door handle it will unlock the door but not open it unless you release the handle and pull it again. Or if you hit the unlock button then the door will open on the first pull of the handle.
I had it all apart again to see if I did something wrong but it seems together as it should be. Is this a module issue or did I do something wrong?
Looking forward to some guidance.
1 - 1 of 1 Posts
