I like yours too!
Right area for this:confused: When I go to lock my doors,I have to "lock,unlock" to lock them. I hit "lock" and just the pass door locks.....I unlock then "lock again and both doors lock. Does it need to be reprogramed? If so....how?
I'd say it does need to be reprogrammed, yes.
It's most likely the central locking portion of the ECU or the comfort module in the car itself. You should be able to do it with VAG-COM... check around the forums for the "VAG-COM Sharing" thread ( http://newbeetle.org/forums/showthread.php?t=495 ) and you should be able to find someone close by that can help you.
Other possibilities are the batteries in your remote are going and it's just sending out weak or corrupt signals. Did it ever work right?
Sounds almost like your locking system is set up to be a right-side Eurpean driver... but, then, not quite.
Oh... yeah... almost forgot... your dealer can do the reprogramming, too. Though they'll charge you an arm and a leg, I bet.
