· Registered
I have 1998 pink vw beetle my doors rattle like crazy both on the drivers and pasengers side. I hate the noise so I choose to listen to music loud enough to not hear them. The door has a wide enough gap between the door handle and the rest of the door for me to fit a piece of paper which makes the noise a little bit better. I had a very bad paint job 4 years ago and the painter left everything inside my car loose including window switches , door handles and so on. Is there any way I can fix the doors myself or should I take this to a professional?!
· Premium Member
It is possible to take them apart and either add fiberglass or u can add some hot glue in there and hope it stays.
It is pretty common for these to break in the area where you are showing, but that looks like the spot where the pieces are plastic welded on the back side. You need to get the panel off to fix that permanently. If want a temp fix put some hit glue where the paper is and hold it down until it drys.
Sorry you had a bad experience, unfortunately these door panels are destroyed if you don't take them off correctly.
Sent from AutoGuide.com App
