1 - 1 of 1 Posts
Ok so working on my daughter 2000 NB with NO BLOWER CONTROL OR AC LIGHT.
I followed some many of y'all great advise and pulled apart the blower switch in center console. It was broken as so many have described with the metal tang off. I repaired that. Tested for voltage on the C shaped metal resistor switch and found about 11 volts. Put it all back together and still not blower or AC light. (the recirc light does light and the doors are heard to move) Moved on to the blower (well under the glovebox as I did not want to go to the work to pull if it was a simpler problem like a plug) - found 4 wire connector on right side of what I believed to be bottom of blower motor - pulled the connector (4 wires) under the glove box and tested for voltage. NO VOLTAGE tested as follows: went green wire to all other wires and all wires to frame ground and no voltage.
So where should I head next? Yes I have checked R/R the 25 fuse? Thanks in advance
1 - 1 of 1 Posts
