VW will likely tell you to pound sand and not all transmissions has the extended warranty coverage for the valve body.
86k miles is right on the upper side of the VB problem.
If you have a 6 speed Tiptronic, they are pretty solid transmissions, but the valve body will need to be reworked. If you can DIY, expect about $700 in parts, it is a pretty straight forward job, if you can find a shop to listen and just put a rebuilt valve body in the transmission, you are looking at around $1000-$1100.
I would NOT take the car to a national chain transmission shop, you will be scared into a complete $6000 transmission overhaul.
I agree you probably won't have any luck with VW unless you are very good friends with the service manager. Find a independent transmission shop and see if they'll listen to what you say is wrong. If they won't don't be afraid to go to another one. I wouldn't entirely stay away from a chain shop as some are actually pretty good, but regardless, don't let them talk you into a new transmission.
Thanks for the input... I figure I won't have much luck. Also - I don't think I'd ever hit a chain transmission shop unless I had money to toss down a hole!
I'm currently not having any shifting issues (knock wood) so I hope it stays that way.
I do have some sort of issue going on... Which I'll describe in a new post since I don't really know if it's valve body related.
Related Threads
VW Beetle Forum
979.7K posts
74.1K members
Since 2005
The New Beetle forum, come in and join our discussions on the new Volkswagen Beetle. Talk about modifications, performance and color choices.
