Good morning all
My wife's convertible 2010 bug's drivers side window is stopped in the 1/4 down from closed position. The door lock and the power mirror are no longer working on this door. I can let the other windows down with the all window switch. But the drivers window is suck in that position. Fuel door switch and trunk switch work
Any thoughts.
Thanks.
Sounds like the door controller which is part of the power window motor assembly. The gas lid and trunk release don't go through the controller. Others with a bad controller can sometimes get them to work for a 10 minute period after disconnecting the battery negative cable momentarily. This may allow you to close the window, at least.
