Step By step Fixed the window probem in car..
Locate the fuse box, usually under the dashboard near the steering wheel, and check for blown fuses, easily identified by a break in the metallic strip running up the center of the clear fuse.
Replace the fuse and see if that fixed the car window.
Check for loose wires going into or coming out of the fuse box.
Check the window control switch.
Remove plastic access panels on the door following manufacturer's directions.
Pull back insulation, if your car has it, to expose the electric window motor.
Tape the window glass in place in the closed position using masking tape to prevent it slipping down while working with the window motor and regulator.
Replace electric window motor if necessary, following instructions included with new motor.
Take the window regulator out of the door panel by removing the mounting bolts
Remove masking tape, and check window operation to make sure it is working properly.
