I feel silly posting this but I am stumped! On the drive to work yesterday I noticed the drivers window wouldn't go down. It doesn't drop when I open the door, use the key in the door or anything. All the other windows work fine. The top will not work as well. I was leaning towards it being a bad microswitch in the door lock assembly but that shouldn't effect just the drivers window would it? I've searched here on the site and though some issues are similar to mine none are exact. Could it be just a bad fuse? If so which fuse should I check?
