I was driving the bug to work today to fix some air leaks
Codes I pulled were:
P2279: leak in air intake sys
P1151: Long term fuel trim additive air; bank 1 range 1
P0300, P0301, P0302 Missfires
On my way to work (30 miles) the cars gas pedal went dead, feels like the car fell flat on its face, blimp the gas pedal a few times andthen everything was fine again. did this twice to me.
Any suggestions?
I do have a Vagcom
Discussion Starter #2
Ok, think I found the leak, the air pump valve is comming apart
058 133 753B, so i'll get that replaced today and hopefully the pedal problem is related
Any suggestions?
I do have a Vagcom
Could be the rheostat in the throttle pedal. Can you use the Vagcom to record the throttle input as you drive? That should show if it is tracking correctly.
