Okay when I click my key fob to unlock my door, it unlocks the passenger door but not the driver.
It will also lock passenger and sound horn 50% of time when I lock with remote.
Battery going out in fob or something else or is that what it's supposed to do?
Been doing that since I bought it, so I lock manually with key.
Does it act the same way with any other key fobs you have? If the problem is consistent; you might have problems with the switches' sold joints cracking inside the door lock. These can be replaced or repaired (re-solder cracked joints/switches); you might scan your car with a vw compatible scanner, to see if you have any trouble codes (look on amazon for a vs450; under $50).
