1.8T Forge 008 Premium DV - $184.95 w/ Free Shipping
This new FMDV008 is smaller to fit in tight spots, and tougher, with a more secure bolt-on cap design. The new design responds faster, and its improved airflow characteristics give your car a high performance sound and feel. Get one today and you can spend more time driving and less time fixing.
Cool-looking DV; what kind of engine-power levels is it suitable for sustaining? 250HP?
I would bet a little bit more than that. Heck the improved BOSCH (OEM) version can handle 250HP. Those Forge DV's are pretty tough and are piston operated with no diaphram to rip so I would imagine it could handle 500 HP easily.
When upgrading the DV you will add the correct spring for the right about of boost you are running. Unit is good for all HP levels!
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
I'm not a dude.
Doh! Just bought a 007 a few months ago. :( I would've held off if I knew they were coming out with this!
