Volkswagen 2.5 Oil Filter Housing Drain Tool - $49.95
When it drains it pours. Nobody wants a hot oil treatment to be part of an oil change. That's why you need the Schwaben oil filter drain tool. Just screw it into the filter housing and send your drain oil to a catch can for easy disposal. The screw-on adapter is machined from solid brass, with non-slip knurled collar. The swivel base and long drain hose are easy to use in tight quarters.
Tough enough for repeated use, the Schwaben drain tool belongs in your tool box if you own a VW 2.5L.
