Have a 2913 VW beetle Fastback has good batt. Car is dead no light 4-way flashers nothing works .Master fuse ?
Check your battery cable connections a loose connection can cause no start problems. When you say battery is good what does that mean? New? You put a multimeter on it and you read 12.4-12.7?
Disconnect the battery, then turn the ignition on, leave it on and reconnect the battery, start the car. It should be rest now.
