My Beetle (2005, 1.6L, Cabriolet) has done over 100,000 miles and is burning too much oil (so failed its NCT/MOT/test) Garage suggesting changing catalytic converter without being sure this will solve the problem. I am considering getting the engine reconditioned instead (haven't got a quote for this though yet). I understand that the resale value of the car will only go up as these cars are no longer being manufactured. I'd be grateful for any thought or suggestions. I am in Dublin, Ireland. Thanks.
Do you have smoke coming out of the exhaust?
Hi, no; it's CO level at 'low idle' is 0.68% (pass rate: 30%); and at 'high idle' it's 0.25% (pass rate 0.20%) (HC is fine: 187ppm, pass rate 200ppm). I'm going to try chucking some Cataclean into the fuel and give it a run before the test. My previous mechanic (in the UK) used to do this and we'd get it through. It that still fails, I think I'll have to get new cylinders,/overhaul the engine...The car and engine are in fine fettle otherwise! Any further suggestions let me know!
Have you scanned the car for any codes to see if there is maybe another cause for those results?
This video, is a great thing to check out; a basic infrared temp gun and a scan tool, can confirm a cat issue:
If you think, you are dealing with oil use and potentially ring issues, we have been working through a problematic 1.6L with smoking issues here (re-ring and hone; seems to have fixed it).
Discussion Starter · #7 ·
Mechanic has in previous years, nothing came up. Certainly if I don't get through on the Cataclean I would expect mechanic here to do so before taking engine apart.
2006 1.6 Beetle Luna Cabriolet
If its burning oil, then it can be leaky valve stem seals or oil rings, Can u remove the spark plugs and see what they look like? U can also use something long and thin like a cable tie to dip it through the plug hole and see if any cylinder has oil sitting on top of the piston. What oil are you using? A contaminated or plugged cat will also could an issue if its burning oil....
