I have a 99 beetle and since Friday I have had an issue I suspect to be electrical. The car goes off after about 7 minutes driving and you must allow it cool for about an hour for it to drive again. The electrician who checks the car noticed that key fibre had been burnt. I replaced it but the problem won't go away. He's now suggesting I have the car scanned. Any ideas would be invaluable.
Scan for codes and post any you find; most auto parts stores will scan your car or loan you a scan tool for free.
Typical issues, related to your dying problem you are experiencing are; failing fuel pump or engine speed/cranks sensor.
Scan for codes; post any you find and we can go from there Thanks.
s: if you need to replace parts, stick with oem brands, crank sensor Bosch and fuel pump VDO or Bosch with the latter offering a built in fuel level sensing unit, new tank seal, at a lower overall price.
Thank you. I will share whatever I find. I am currently waiting by the street to cool for another drive to the scan.
