I have a 2003 turbo s beetle, I changed the fuel pump recently, the check engine light came on a while back and the code was a P1152-long term feul trim. I checked the mass air flow readings and it was not working properly. I changed the mass air sensor.
then a fuel pump relay fault code showed up. changed the relay.
Then a 17069 code for ECM power relay open circut intermittant along with 16519 for Oxygen sensor no activity.
I checked the oxyen sensor connections and changed the ECM relay.
the next under readiness came up Secondary air injection failed.
I checked the relay board and connections under the dash.
Then cleared the codes once again, then received a missfire cyl 1, 4, 2 apon restarting the car at idle.
I cleared those when finding no problems with coils or plugs.
I drove the car and it seemed fine but when a came to a stop it just died. restarted and continued and then parked idling and it died again. now a code for fuel level sensor open or short to intermittant.
Any suggestions????? where to go from here?
thanks
thanks
