HELP.. I just spent 2 hours putting the TB on, and now I can't get the engine mount back on..you know the piece that actually bolts to the engine.. what the H is the trick?
:mad::mad::mad:
I ended up inserting engine mount bracket first (but not bolting it) and then tensioner with the assistance of another person. And I also ended up lifting engine up. However it doesn't look like I can lift it up high enough for easy manipulations as intake manifold hits rain tray or something.
Now I'm struggling finding suitable pliers to adjust tensioner.
Thank you
:)Got it, lowered the engine, and was able to put it right in. THANK YOU people for the help.. the other trick i figured out is when putting the a/c pump in, I put the bolts through first and started screwing on a bit, then hammered the bolt head a bit to knock the "nut" back a little, it worked perfect.. thanks agian..
:D:D
Why did you remove it in the first place? I've only removed alternator as it gave some space at thermostat and someone before me didn't secure lower bolt properly anyway.
