Hey folks. Just thought I would share some beetle drama. Ive had this car about 3 years. 203kmiles. Engine will just turn off. Under load usually. So I started way back with a fuel pump and relay. Put a napa relay. Sets a code but works well at first but a week later, same thing. Put the vw relay back in, have 3 of them and tried them all. Still dies. So I did the lazy thing and put new sensors. Both had already been replaced by someone. Still new. A week goes by and it starts again. I replaces the shady autozone cam sensor with a napa one which was bosch if i remember...anyhow. Same. Same same. So then I noticed something. I had the idea that the ecu was having a bad ground or lost power. If I coast down from 40mph or so with the key on the engine seems to spring back to life. Once I had to pull over and restart. It happens almost every day, seemingly about the same time it would go into closed loop. Rarely rarely with a fully warmed engine. Once it does it and I restart it it will drive fine all day long. So I thought...hmm..02 heaters..air pump, closed loop..maybe 02 heaters and the air pump are pulling too much current for 203000 mile wiring. Maybe the ecu is dropping voltage when these high current draw is happening. I have an obd11 (not really a fan though) and Torque as well which seems to do just as well on this car anyhow. And its easier and faster..both have Something the other doesnt do.
Anyhow. I noticed the HO2S's heater circuits all run through the coil side of the airpump relay. Probably because the air pump will only turn on when the a/f sensors are warming. So. I took the "100" Air pump relay out and had a spare german one. The one I pulled out was a portugues AE relay (black cap). It wasn't corroded at all but I measured the coil terminals for resistance and it was 62ohms where the german "100" relay was 72 ohms. I had another AE100 relay and it was also 62ohms. So today I cleaned the terminals, cleaned the points inside the relay and put the german one (I say german but I don't remember the name, just the audi logo) with a grey cap in the panel (next to the brake fluid reservior for those who don't know where it is). And now I wait for my morning slow drive to the parts store to buy a strut bushing kit because my pass side collapsed going over the RR crossing today. Lol. These are the crankiest neediest little cars. "Please daddy...put your wrenches on me?"...
Ill keep you posted. I am really hoping it will go away. I guess the next thing would be to verify ECU power and ground voltage drops. Check and clean grounds. Oh...another detail. Sometimes if Im under load when it quits Ill get a charge sensor code. Only if it quits under load though. I also need to see if the DLC (obd2) is losing power or data. I haven't had either scanner on when it happens. But the tach goes dead..Im using torque to monitor A/F and engine temp. I dont think I can poll the cam and crank sensors with the obd11 but Ill look at that again too. If anyone had any other ideas I would be happy to hear them. Oh..I redid the ground cabling and starter cable last summer. Fatter cables and cast soldered and hex crimped cable ends...new battery.. Ive thought about adding a ground strap too.
