The n75 is easy to test and as noted; you might use a heat gun or hair drier; to add heat to compare resistance difference.
Note: on my N75, cold my original n75 the resistance seemed to be in spec and not much different then a new one. I didn’t add heat; i read about that testing addition until later but it makes sense to do so.
The replacement made a difference; as noted, a new dv and n75, eliminated a boost hesitation issue i struggled with for years. Off the line, the boost would dip, engine seemingly “fall on its face,” then recover; post new parts install, the boost was improved, more responsive and smooth. It was very satisfying fixing this problematic issue; very frustrating, driving around a 1.8T with boost issues, no trouble codes, never knowing what the problem was and my initial testing of the parts, did not indicate total failure, following the VW service manual testing procedures. I’ve come to the conclusion, that many parts can be in a “soft failure mode”; meaning, functional but not at their optimal levels, which can adversely affect normal boost operation.
This, was two important things, that really helped my 1.8T run better, related to boost but there were and are many other things to go through, check as well. All the various parts, of the engine control system, fuel, induction, ignition, etc; all play a role in a good, solidly performing 1.8T.
