1 - 9 of 9 Posts
I have a 2006 NW 2.5 engine manual transmission check engine light was on due to secondary air pump (no light now it was pending) but i was driving and the car jerked and the epc light came on i drove it another 15 miles. Turned off the car and let it set for a few minutes. It hasn't done it since. Has anyone had this happen to them?
Rather than launch into a detailed explanation, I found this fairly concise summary with a quick search. To narrow things down and identify the actual problem you will need to get the car scanned, preferably with vcds but auto zone and other car parts stores will scan your car for free, however they use cheap scanners that may not pick up all the trouble codes your car is trying to tell you about.
WHAT IS A VW EPC WARNING LIGHT
The EPC warning light is an instrument cluster based LED found on all Volkswagen, Audi, Seat and Skoda vehicles fitted with a drive-by-wire system and EPC stands for Electronic Power Control. However the EPC warning light is not exclusive to these VAG cars, most other motor manufacturers also have them, since it's legislated to be part of the OBDII system. This EPC light when lit displays the letters EPC and primarily warns the driver that there is problems in the engine's torque system - (acceleration system). The reason why the EPC turns on, problem could be many, among which are the vehicle's knock sensors, its throttle system, its cruise control, its mass air flow system, its engine speed verification system or any of the other associated systems that cooperate in the drive-by-wire schema.
When this EPC light comes on, the vehicle’s throttle valve (butterfly) may be limited in order to protect the engine from damage. It prevents the engine from revving above 2000rpm. This is known as limp mode and the ECU permits just sufficient power to drive the vehicle to a service center for repairs. To remedy the problem, the vehicle’s ECU should be scanned with an automotive diagnostic too, in order to extract the DTC's related to the torque problem. Cars with an accelerator cable are also fitted with an EPC light but the ECU software is quite different, yet the overall principal remains the same.
All Volkswagen (VAG) vehicles have a whole array of dashboard warning lights in their instrument panels, specifically designed to alert the driver to any vehicle malfunctions or problems. In fact so does all most modern day automobiles. Having said that, it is only a matter of time before these lights start lighting up. Invariably and inevitably all cars will breakdown at sometime or the other but its nice to be warned about a mechanical problem before it actually occurs. For example, having a low coolant level light or an low engine oil-level light flash at you, accompanied by an audio alert is a blessing because complete loss of either coolant or engine oil could result in a very expensive repair.
The one warning light that puzzles most drivers is the VW EPC warning light. Driver often ask, what is the VW EPC warning light? Like I've mentioned above, it is a bright yellow dashboard light with the letters EPC inscribed in bold.it When lights-up to draws your attaention to a potential malfunction in the EPC system. When it lights up whilst driving and the trouble is related to a safety issue, the car will more than likely go into limp mode. This may sound quite serious but in most cases it's not. There are several reasons why EPC Dashboard Warning Light turns on, but through a process of elimination the cause can be tracked down fairly easily.
The Engine Speed Sensor is known to cause the EPC light to turn on. The engine speed sensor is a proximity magnetic transducer counting the revolutions of the flywheel / crankshaft and sends a steady stream of pulses to the ECU. So when this stream of data is interrupted for whatsoever reason for only a fraction of a second, the ECU detects this and turns on the EPC lightand cuts power to the engine. It does this to protect the engine from damage.
If you have a scan tool, check for DTC errors. The following error code, 17745 /P1337, 17746 / P1338, 17747 / P1339 and 17748 / P1340 are the troubles codes that provides a tell tail sign that the engine speed sensor is either loose or faulty, hence the car's engine cuts-out whilst driving and the speedometer is inoperative. But in some cases the engine will start again. When this symptoms repeats itself often, you should know it is time to replace that pesky engine speed sensor.
The Accelerator Pedal itself is often the main culprit that causes EPC problems. A telltale sign is that the engine idles a lot faster than it aught to. To verify this, physical pull the accelerator pedal away from the floor board while the car is idling. If it reduces the engine's revs back to normal, then it is time to replace it, because the potentiometers that's built into the the accelerator pedal, have gone faulty. Accelerator pedal problems are numerous and the following DTC, 16504 / P0120, 16505 / P0121, 16506 / P0122, 16507 / P0123, 18038 / P1630, 18039 / P1631, 18040 / P1632, 18041 / P1633, 18042 / P1634,are linked to accelerator pedal errors.
Mass air flow sensor is another engine component that can cause the EPC light to turn on. Cleaning the mass air flow sensor with compressed air does often solve the problem but if the issue persists, its time to replace mass air flow sensor. But before changing it, check to see if any of the rubber hoses in its vicinity isn't perished. An leak in Air Intake System wil allowing air unmonitored to enter the intake which will throw a P2279 / 15093 error or a P0068 / 15101 error.
The Throttle body is by far the most common cause of an EPC problem though in many cases it is not the throttle body that's at fault but rather that it the needs to be recalibrated (adaptation). The scan codes like P2135 / P2136 / P2137 / P2138 / P2139 and P2140, will give a good idea as to whether or not the throttle body require replacement. But in many cases it turns out to be wiring harness issue. The plugs that connects the throttle drive motor and the throttle position sensors is fairly troublesome ad should be checked before throttle is replace.
The Brake light switch can also cause the EPC light to come on because the torque control circuit uses the brake light signal as a ECU input signal when the car decelerates.
The Injectors and the Ignition Coils can also cause the EPC light to turn on. I've heard that an incorrect spark gap on the plugs can also cause an EPC problem but haven't experienced it yet. Driving with very little gasoline in the tank can also cause the EPC light to turn on because the high pressure fuel pump may lose pressure which then notifies the ECU to inhibit the torque circuit and switch on the EPC light and make the car go into limp mode.
I've experienced the Knock Sensor turn on the EPC light. Spirited driving also turns on the EPC light.
So as you can see there are several things that can cause an EPC fault. This is not a complete list of EPC problems but as new ones are identified, I will post them. The following questions prompted me to write a synopsis of what an EPC light is!
___
Do you have a vw specific scan tool? It would be a good investment; it help you diagnose the problem, by first reading the related trouble codes.
Popular vw scanners;,are vcds by ross tech, OBDEleven and the many “vag” Chinese knockoff handheld scanners on Amazon, etc.
If you’re interested in purchasing one discussed your budget and we can discuss things, options and go from there. Thanks!
What can I get for $100-150?
Thanks
2.5l 2013 conv
1 - 9 of 9 Posts
