When I press the ESP button on the dashboard the warning light within speedo illuminates, but is the button supposed to illuminate too, like the hearted rear window switch?
I'm having a similiar issue but my light stays on constantly. I have changed the brake light switch and 4 wheel speed sensors with no luck. Thinking now it may be the switch...Any thoughts?
Your best bet is to find someone with vcds which can read your abs system so you’re not just shotgunning parts at the problem. There should be an abs code of some kind that can point you in the right direction.
