Greetings my fellow Beetle enthusiasts
I was finally able to get some codes read on Mrs. Beetle. The check engine light comes on and goes off at random. I have to disconnect the after-market radio to read the codes. Here is what is going on:
at 92452 miles, codes are:
P0441 EVAP Emission Control System Incorrect flow (could be faulty gas cap)
P2261 Boost Pressure Control Valve (N249) Mechanical malfunction (could be something wrong with the turbo)
P0327 Knock Sensor 1 (G61) Signal too low static - no define (could be crappy fuel) (is this knock sensor buried on this model Beetle under the intake?)
Readiness all failed. Cleared codes.
at 92522 miles, codes are:
P0441 was gone.
P2261 and P0327 are still present.
Readiness all pass. This was after driving 69 miles after clearing the codes.
at 93230 miles, codes are:
all of the above codes are present plus a new one:
P0455 EVAP System: large leak detected static - no
For Readiness all systems pass.
Fire away! I've got my seltbelt on for the bad news--a five point harness for this!
--Mrs Beetle
P.S. I almost forgot. I replaced the fuse for the back up lights and it blew (again?). There is a short somewhere. Feel free to chime in on this too. Might as well.
P0441 was gone.
--Mrs Beetle
