1 - 14 of 14 Posts
How do I access my evaporator core? I have desiccant from the receiver/dryer in my AC system. I am in the process of replacing: Compressor, discharge hose, expansion valve, receiver/dryer. I would like to disconnect the hose going into the evaporator to flush it.
A few weeks ago I repaired the blend door (AC distribution box)& cable, and blower switch. I must have been close to the evaporator. I could see the blower motor (under the glove box).
Can I get access to the hose connection by removing the glovebox and blower motor, or do I need to pull the whole dash again?
I have a Haines Manual, but do not have The Bentley Repair Manual yet.
No NB Yellow Trifecta :(
It is inside the plenum box and yes you will have to remove the dash again; the green box shows the location of the evaporator core. If all you want to do it flush it out; you should be able to that from the fire wall connections.
The yellow box is where the relays are.
Thank you
Thanks for the reply and the great photo.
I removed the evaporator expansion valve so I have access into the firewall. (see photo with desiccant still in valve). I assume I can disconnect any hoses or lines going into the evaporator inside the car, that way I can flush the line segment clean and reconnect with out putting any chemical flush into the evaporator.
You've got quite a monumental project going on, an ugly mess. Have you determined what caused the receiver-dryer to fail? Compressor failure? I'm not a a/c guy, and it's one of the things in a vehicle I have not had occasion to work on. The vehicles I have owned that have needed a/c work (becasue of age and mileage, have all been GM, so the receiver-drier (GM equivalent to the accumulator) and thermal expansion valve (GM equivalent to the orafice tube) are a new learning experience for me. That being said, I have been doing a lot of research (searching and reading) helping out three other Orgers on three other threads who are also dealing with a/c issues (none as serious as yours). In addition to the web for research, I also have a Bentley.
What I've learned, and as a lesson and a warning to others, the receiver-dryer is a service item, with a usable life of 4-5 seasons. Also, when the system either has a leak that results in the loss of the refrigerant, or when the system is open for more than a matter of minutes, the receiver-dryer MUST be replaced (I knew this from my experience with the GM equivalent, the accumulator). When an a/c system has the refrigerant evacuated, you loose much of the compressor oil, the oil that lubricates the compressor (when replaced, the compressor comes with the correct type and amount of this oil already in it). If the compressor is not being replaced, oil must be added (I didn't know that), otherwise you are almost certain of ultimate compressor failure. In the event of a compressor failure (not the clutch) or as in your case the receiver-dryer failure the entire system must be flushed. You have discovered this with the evaporator. Also be aware the condenser will need flushing along with both the low pressure and high pressure lines. What I have learned about flushing the system, is that this is done with both compressed air and special flushing agents and equipment designed to remove all contaminents and compressor oil. Compressed air clearing of all parts and the the flushing of the system are always done in the direction opposite the direction of flow of the refrigerant (but that only makes sense). Also, all components are disconnected and flushed individually. The Bentley indicates that each and every "o" ring in the system must be replaced (there are numerous). It also indicates compressor oil and flushing agents are very specific.
For anyone wanting to learn more about the operation and servicing of their a/c system, there is a lot of information, including links to outside sites in these two Org threads.
http://newbeetle.org/forums/questio...-long-time-cool-but-when-does-works-fine.html
http://newbeetle.org/forums/1-9-liter-tdi/50882-ac-problems-my-tdi.html
If I can be of help to you, with my Bentley, I have the paperback paper version and can copy and scan, let me know. I'm familiar with old school Haynes, but not the NB Haynes, so I don't know what information you already have access to. From the subject of your post you may have limited information.
Btw, a nother Orger just put up a Bentley FS, $80 shipped (excellent price), here
http://newbeetle.org/forums/new-beetle-classifieds/50936-volkswagen-new-beetle-service-manual.html
MORAV
Evaporator Core
Thank you for your response and for the A/C info. This is my first time attempting any AC repair/service. I am not sure if the dryer has ever been changed in my 1999 Beetle. I have had it charged once tthat I can remember since I have owned it in 12 years. And that was after it broke last year.
I would love to see the Bentley information. I did purchase the Bentley CD from Amazon. It is supposed to be a new copy but was used and I could not activate it. Amazon will send me another one but will probably be another week or two. I am already day 14 with my car on jack stands. The NB Haines manual is not too bad (it jumps around alot), I was able to figure out how to pull the dash apart. But there is nothing about the evaporator core.
I am at a standstill with the evaporator core, as I am not sure if I can or should remove the lines or not. I do not want to aggravate the situation by adding chemicals "flushing" the core if I am not susposed to. Do the two lines from the expansion valve through the firewall go in and out of the evaporator core as a closed circuit? Can I just flush at the firewall opening and not worry about damaging the evaporator core or disconnecting the lines? I do not plan to replace the core if it is not necessary, so is there any reason to try and access it from under the dash? The desiccant pellets are very hard, I hope that they stopped at the expansion valve, as the opening is physically too small for them to travel through the valve to the evaporator core.
I am replacing the discharge hose, compressor, dryer and expansion valve. I have a bag of new o rings. I already have a shop air compressor, and bought a new vacuum pump and AC gauge set. I plan to use compressed air on each part separately, including the condensor, then flush each section until clear with a spray chemical I bought at auto zone (see photo).
My original VW compressor had no oil come out of it even when turning the clutch. I added about 3.5 ounces to the new compressor, which is all I could force into it, even with turning the clutch. The new compressor had a few tablespoons of oil in it, and the directions said to empty it and replace with the same amount in the old compressor. Just from looking on line it seems like about 4 ounces was a standard recommendation, no recommendation in NB Haines Manual.
I added 13.5 ml of oil to the dryer (I read those instructions somewhere). I did not add any dye to the system, I think I will buy some and add it before it goes back together, I should have room for about 0.5 ounces, I guess I can just add it into the new discharge hose.
I plan to pull a vacuum on the system when it is assembled. And take it to a service center to charge the system and look it over when I am done. Especially since it is my first repair.
I found the low pressure access on the front passenger side of the car, above the radiator. Where is the High Pressure access? Passenger side, close to fender, back by expansion valve? (see photos)
I feel for you buddy! You so need to see and read the Bentley section on A/C. DON'T do anything more until you see it! I can and will do this. When I get home this evening (I don't have the Bentley at the office), I will copy and scan into a .pdf doc all the relevant pages, I think maybe 15 or 20. Flushing methods and the approved solvent is addressed, as is the compressor oil thing. I read that the new compressor was all ready oiled and new oil would not be needed or need to be added to. Perhaps that was in the Bentley, or here, or in the changing compressor link in this link (this a good read also about generalities)
Auto Air Conditioning - Replacing your auto A/C compressor
While I am a MS here, I post an awful lot of things, and ultimately will use up my alotted memory. This might be too big a file to attach anyway. I never know until "it"tells me. Truely there is also a copywrite issue. Would you mind if I emailed the file to you. (that's someting that can't be done thru the Org email system (attachments). I have an email I only use for my forum communications with fellow members, run commercial anti-virus, don't abuse email addresses with bulk mailings, and I never share an email address with anyone, not even by accident. I'll need your email address if that is okay with you, via p/m.
MORAV
Discussion Starter #8
Evaoprator Core
That would be "I feel for you Babe" not buddy :)
I can not wait to see the Bently information.
Because I think I am over complicating things.
I am curious about:
Can I flush the evaporator core?
Where are the high and low pressure access ports? (See photos)
What is the green cap port for (see photo).
Is that an inline filer? I have read somewhere that any lines with an inline filter should not be chemical flushed (see photo)
I am working on ordering a Bently Hard Copy as well as the CD.
Thank you!
Yes, I know now, slightly embarrassed, made amends in p/m (lol)
I am curious about:
Thank you!
Mornin' Darlin'!
Email sent; Complete BENTLEY Section 78 - Air Conditioning in .pdf file.
M.
Any chance you might still have that Bentley Section 78 info available? I'm about to replace an evaporator coil/drier/expansion valve in an '03 Beetle.
If not, I understand. :)
This was a great thread a couple of years ago since it was posted, was wondering how the repair turned out.
I'm about to overhaul my AC system in the 01 beetle, guess I made the fatal mistake of using stop leak and jacked up everything.
bad stuff
Sorry to hear that. You might have to replace condenser and evaporator also. Remove all the lines and flush them out. I just did mine a few months back and it's a job and a half.
lucky for me I only had the compressor fail but I still flushed everything out. I wouldn't buy any parts from ebay or china junk cause you'll be replacing those parts again real soon. Good luck man
here is a pix of when I did mine.
1 - 14 of 14 Posts
