I need assistance diagnosing a blower fan like noise on a 2004 VW Beetle 2.0 Liter Gas with 177k miles.
Here are some of the symptoms and things I have tried to isolate the problem.
1
Kindly make suggestions or other troubleshooting steps I should try.
Thank you...
1
. Its sounds like a blower fan that is starting to go out. It not loud, it just more annoying than anything…. But I don’t think it’s the blower fan.
2. The noise appears to be coming from inside the dashboard.
3. When the car is in park and the blower is turn on, there is no noise other than what one would expect from the blower fan.
4. When in park' changing the blower fan speed doesn’t seem to cause the noise.
5. If I rev the engine while in park, there is no noise.
6. When driving, with or without the blower fan running, you hear the noise.
7. The faster you drive the higher the pitch but it doesn’t get any louder.
8. While driving at any speed, if you put the car in neutral, the noise persists.
9. While in Drive but stopped (say at a stop light), there is no noise.
10. The speedometer appears to be working as expected and it does not jump around or anything.
11. The Odometer appears to be working correctly too.
12. There are no check engine lights or any indication that the car has sensed a problem.
Thank you...
