So the fans have apparently been eating away at the coolant hose located at the front top of the car that connects the upper radiator hose to the water pump. I've known this for awhile you can feel it, it started to slowly leak so I replaced the hose. It's bracketed in at the middle of the hose and the hose is close to the fan, but I turned the fan manually and turned the car on and it did not touch the hose. I never saw it touch the old hose either. Well, I look at it a few weeks after I changed it and the new hose is ate up at the same spot. I'm ordering a new hose just in case, it's not leaking right now, but in the meantime I'm thinking of putting a zip-tie on just to hopefully move it out of the way enough. I would really like to know why the fan is hitting it though, or if I can move the fan back, or something. Like I said from what I can tell when I move it manually or turn the car on the fan doesn't hit the hose, and the fan is stable. If anyone has any better ideas other than a zip-tie it would be much appreciated. I am frustrated!
Thanks!
Thanks!
