Tools and Equipment needed to tackle 99% of your maintenance and repairs.
  • number 15 Torx screw driver
  • Number 20 Torx screw driver
  • Number 30 Torx screw driver
  • Number 1 Phillips screw driver
  • Number 2 Phillips screw driver
  • Flat blade screw driver
  • 10mm socket
  • 13mm socket
  • 17mm socket
  • 19mm socket
  • 5mm hex bit
  • 5.5mm Hex bit
  • 7mm Hex bit
  • 8mm Hex bit
  • 17mm hex bit
  • 3 inch extension
  • 6 inch extension
  • 3/8" ratchet
  • 10mm box wrench
  • 13mm box wrench
  • 15mm box wrench
  • Torque wrench
  • channel lock pliars
  • needle nose pliars
  • Oil filter pliars
  • wire stripping kit
  • electrical tape
  • selection of mini and reg buss fuses
  • Oil drain pan
  • 20 rags
  • Assortment of zipties
  • 4ft of 3.5mm vacuum line
  • Assortment of 3.5mm vacuum tees
  • Box of latex gloves
  • Silicone spray
  • Blue Loctite
  • CRC Disk Brake Quiet
  • CRC MAF cleaner
  • CRC Brake Cleaner
  • Liquid Wrench
  • GoJo Hand cleaner
  • Floor jack
  • 4 Jack stands
  • 2 Rhino Ramps
  • Tarp/Cloth, Mat or Creeper to lay on.
  • MetalNerd Brake Reset Tool (click here)
I would also add several oil filters, drain plug washers and extra oil to your garage. So that you are in a constant state of ready. :)
y2k Reflex Beetle 1.8t
Bumping this post from 2006 because my beetle's almost 20 years old and this was a super handy list for making a bare bones tool kit i can keep in the car and I'm a preparedness fan. I added a flashlight, a spark plug socket, a generic obd2 code reader, spare bulbs, jumper cables, a mini sharpie marker and a utility knife. A multi-tip screwdriver saved space and weight. I always put a strip of paper between the battery and battery lead of the worklight so it doesn't discharge or leak acid.) Happy prepared travelling y'all!
