Hi all,just wondering if anyone has any ideas or experience on this issue,started a few months back when my handbrake /emergency light on the dash would intermittingly dissappear then come back on when parked at the lights.Recently it has just gone altogether and now the EPC light has popped up.Got a scan done but no faults came up,guy said that a message stated that the ECU had been tampered or bypassed in the past! Checked and replaced a stop/taillight and a reg light that had just blown this week.But am confused wether to strip and replace the handbrake/brake pedal sensors and hope for the best.Just don't want to throw money down a road then find out it could be worse.Any help would be appreciated!?
This maybe a situation, where a vw specific scan tool; would be needed to read codes for this type of problem.
Seeing how you have a 1.6L, i assume you have a uk spec vehicle and some aspects of the cars electricals maybe different as a RHD vehicle. You might considor purchasing th UK spec Haynes service manual and use the correct repair info they provide to complete the repairs.
VW Beetle Petrol & Diesel (Apr 99 - 07) Haynes Repair Manual (Haynes Service and Repair Manuals)
https://www.google.com/search?q=VW+Beetle+Petrol+&+Diesel+(Apr+99+-+07)+Haynes+Repair+Manual+(Haynes+Service+and+Repair+Manuals)&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Here is the LHD service manual for a 2002 model with a 2.0L:
#11 is the switch:
http://workshop-manuals.com/volkswagen/new_beetle_gls/l4-2.0l_(azg)/brakes_and_traction_control/parking_brake_system/parking_brake_lever/component_information/diagrams/
As for a scan tool; there are many "VAG" scan tools available on ebay/amazon; otherwise you might check out OBDEleven and the Ross Tech VCDS
https://www.google.com/search?q=vag+scan+tool&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
https://www.google.com/search?client=safari&hl=en-us&q=obdeleven&spell=1&sa=X&ved=0ahUKEwiP2b3hpajXAhVFzWMKHWWZAOoQvwUIIigA&biw=375&bih=559
https://www.google.com/search?client=safari&hl=en-us&biw=375&bih=559&ei=cnf_WePXE42WjwOg5rnwBw&sjs=3&q=ross+tech+vcds&oq=ross+tech+vcds&gs_l=mobile-gws-serp.3..35i39l2j0l3.32273.37462..38073.......1374.5306.0j3j3j1j0j1j1j2............mobile-gws-wiz-serp.....3..0i71j0i20i264j0i67j0i20i263.TBw+2VObfG0=
Thanks Billy,it is an original UK spec car,so will have a look at the Haynes manual and have a go,the replacement parts are only around ?15 so will check them out and update.
