I have a spare AWP engine for my 2002 Turbo S that i plan on going through and building a little. My current engine has almost 300k on it and is starting to show some signs of age. Anyway, i took the valve cover off my replacement and spent forever cleaning it and getting all the black spots off. Used wire wheels on drill and Dremel, sanding blocks, and sanding drums on Dremel. Finally got it clean and all the scratches and stuff out that were in it before i started. I used 3 coats of ceramic primer (thin coats) and then the duplicaolor blue chrome effects paint. I probably should have used a silver or white base, but i dig the color the way it turned out. more of a teal im thinking. the pictures don't do it justice it came out good i think.
After cleaning masked off the entire bottom and gasket area, centers of the plug holes (really didn't need to do that)
and the oil fill seal area.
Final product, this is without any clear. It looks much better in person. I have some high temp clear I may try on it but not sure.
