Year:2003
Make:Volkswagen
Model:New Beetle
Mileage:134000 M
Transmission:Manual
Engine:1.8 Turbo
Trim:GLS
Tornado Red w/ black & red leather. Good condition w/ minor body and paint flaws. . All work done in last 1 1/2 yrs by self. I have parts order invoices. (NEW)trans related: DM flywheel, clutch & p/plate, t/o bearing, input shaft collar/sleeve, seals, C/slave cyl, C/master cyl, bb vac hose,brake & clutch switch, shift cable bush kits:both ends, synt clutch/brake fluid flush. (NEW) suspension: 2 front compl.struts w/springs & mnts, 2 outer t-rod ends,2 ball jnts, 2 rear coil spr. w/mnts, 2 rear shocks w/mnts & bump stps, L rear brk caliper. (NEW)engine related: Battery, plugs/coil pks, valve cvr gasket, fuel fltr, air fltr, synthetic oil & fltr, Down flex pipe w/ cat converter & sleeve clmp.(NEW) body related: Comp. drivers dr pwr window regulator w/motor, pwr door lk switch, driver/passenger pwr dr lock actuators. Prior owner had Timing belt/ water pump kit done @ apprx. 105,000 mi. Has 4 meaty snow tires w/studs, I use as winter car. Runs very smooth & lots of power. I'm looking for next project car. email: [email protected] or (845)796-6351
