1 - 1 of 1 Posts
26mm front bar & 28mm rear bar
Sway bars are used to improve your vehicle’s handling by reducing body lean, as well as solving understeer and oversteer. This sway bar kit from H&R will do just that, giving your vehicle the handling it should have had when it left the factory.
These sway bar kits have precision forged ends and include bushings made from an exclusive urethane/Teflon composite that eliminate squeaks and don't require lubrication. That means no mess no maintenance, just bolt in the H&R Sway Bars and go.
These sway bars are powder coated and easy to install, so be sure to pick up a set to give your vehicle improved handling characteristics.
BRAND NEW NEVER OUT OF THE BOX $300
512-318-6264
1 - 1 of 1 Posts
