FS: Parting out 2001 Sport Turbo LOOK!!!!!!
5994 Views 62 Replies 20 Participants Last post by  StillZeusenergy
Make an offer for prices. Car is silver arrow color. This is what I have:
1.8T 128k miles engine, excellent condition, long block with accessories and covers, wrinkle black valve cover
K03-058 turbo SOLD
3" down pipe with installed o2 sensor SOLD
fuel rail with 317cc injectors
N75 valve SOLD
Wrinkle black MAF with attached cone filter
wrinkle black charge pipe
DRIVER door handle
power window regulator panels both work great no cable problems SOLD
power window motors both sides DRIVER SIDE SOLD
power moonroof motor
power rear spoiler hatch/ trunk lid/ window with motors and linkages (satin black) SOLD
front plastic fenders, grill and bumper cover assembly (partly sanded, no fog lights but setup for them) GRILL SOLD
rear plastic fenders, bumper cover, backup lights, cutout for exhaust pipe
Power window switches driver side
hazard, asr, and defrost switches
sunroof glass panel
both door glass windows
stock intercooler with pressure sensor
washer reservoir and pump
ABS pump (under brake master)
radiator Cooling fans both work great SOLD
Black headlights (lenses and reflectors modified- requires your headlight bodies mine are in rough shape) SOLD
tinted black tail lights
and much more...
1 - 20 of 63 Posts
Also have front end parts like the radiator support and headlight frames too. The radiator support has everything attached to it like the water pump for turbo, all the coolant hoses, wiring connectors, etc.
ill buy the sunroof motor off you and the sunroof interior cover for $50 if you can manage to uninstall it with the rails intact. (my sunroof cover is jammed up and no longer closes all the way)
You wouldn't happen to have an aftermarket skid plate, would you?
I don't have the sunroof cover. You have to pull out the whole sunroof cassette to repair that, which means your headliner and trim all has to come out.
The motor I do have, and will sell it alone for $50 shipped. PM me for details and contact info.
No, sorry!
Have an exhaust? What about a bov?
Hey I'm glad you didn't call me last night I was beat!!!
Feel free to call today!
My bad last night got into putting an exhaust on a wrx. Hey my buddy gave me a full 3inch pipe to build an exhaust with so I won't need that anymore, but I do like that gauge cluster and that shift knob.
Cluster is not for sale BUT the gauge face IS. That's all you need to do this mod anyway, besides cutting up your own cluster to allow the light through and swapping over the servos. You will need mad soldering skills to do it. I will sell you the face and knob for $40 shipped, keep in mind that this face is one of TWO ever made. Difficult to see speed, but tach is WAY BETTER! All indicators are custom too.:cool:
BTW not happy with you, had to pull that exhaust out from under the car today and it was a PITA!!!:mad:
I was just gonna leave it on and ditch the shell!
Sorry man I was going to buy it but my buddy gave me 8ft of 3inch exhaust pipe! How could I pass that up?? And what do you mean by a lot of soldering? I thought it would be just a simple swap
Can you update; what parts you have left for sale? Thanks! :)
its okay I was pulling your leg. :)
it was hard to get out though.
The gauge face is set up for large tach and tiny speedo. You must swap the servo leads internally. There is a thread in here for cup car cluster that has all the info with my original username zeusenergy
A ton.
Entire 3" exhaust, turbo back with all clamps and associated hardware and gaskets
Long block engine with no accessories, head and block, all internals untouched 128k
K03s 058 turbocharger and manifold, both in excellent shape
Power steering pump
All four rotors and pads, nearly new, cross drilled and ceramic pads
All four calipers, painted orange, no problems, includes brackets
Complete front radiator support with radiator and coolant pump, fans, etc
Front plastic bumper/fender assembly/rebar/headlight mounts/wheel well plastics
Same for rear bumper and fenders
Take 5 alloy 17" wheels painted satin black with mounted and balanced 25% tread Toyo proxes 4 SOLD
15mm wheel spacers and longer bolts
Shift tower for top of 5 speed transaxle
Shift cables and shifter assembly
Upgraded 14lb SM flywheel ECS brand with VR6 stage 1 sachs clutch set nearly new
Every piece of intake plumbing, intercooler, hoses, etc
Throttle body
MAF with cone filter
Metal impeller water pump, tensioners, 30k miles, ECS good stuff
Stock pass side motor mount, upgraded driver side BFI stage 1 mount inserts, new dogbone with ECS mount bush
Dash parts (ask)
N75 valve, fuel rail with 317cc injectors, four recent coil packs with no issues or misfires
Switches: headlight, driver door window, trunk release, fuel release, spoiler, more
Almost all coolant hoses and pipes available
Starter, alternator, both used but working
Steering column, column stalk switches turn and wiper
Sunroof motor
Spolier motor (93 MPH version)
Both window motors
wiper motor bracket assembly
and much more!!!!:cool:
Oh yeah! clutch pedal assembly with master cyl and electronic throttle pedal assembly too. comfort control module
and the best tune you can get for the beetle 1.8t: Eurodyne Maestro!!! With ECU cluster board and key pill immobilizer to give you 200 hp right away and upgrades for new turbo installs are FREE after! comes with Maestro cable, Vagcom cable, USB stick with all my files.
headlights and tail lights too, modified black.:)
HEADLIGHTS SOLD
Still going like the energizer bunny!!!! SELLSELLSELL!!!:D
Would like the passenger side headlight mount (the plastic and steel parts), also interested in front bumper cover if shipping isn't too high. I'm in Texas, where are the parts coming from?
1 - 20 of 63 Posts
