ok i have a 98 at 2.0 no CEL when i start the car it idles fine. when i tap the gas it shuts off. when i put it in gear it starts shaking and "drops off" recently replaced the MAF.
Have you scanned for codes? There might not be a CEL, but there could still be codes stored.
Why did you replace the MAF to being with? What brand and part # was the MAF? Poor quality; aftermarket MAFs have caused allot of people problems! It is best to purchase a OEM BOSCH maf; they are the original equipment from Volkswagen and perform, as they should.
You can look up the correct Bosch parts for your car here:
https://www.boschautoparts.com/auto
You can also; test the MAF with a multimeter or a scan tool with live data.
4 wire:
Part 1 -Testing the VW Passat (98-99) Mass Air Flow (MAF) Sensor
5 wire:
Part 1 -VW Mass Air Flow (MAF) Sensor Test (5 Wire Type)
If you still have the original maf; put that back on and see if the problem, goes away.
Everett Street in May
Yep, scan for manufacture codes and do what Bill said, put the old MAF back in and see if the problem goes away. I would probably just start with the MAF swap first.
If you pull any codes, please post them up.
