2001 beetle 1.8t, relay will activate for 3 seconds when the ignition is on, then turns off by it self, cutting off the 12v required to activate the fuel pump, maf and oxygen sensor. Also, when I turn on the ignition, the fuel pump will activate and sometimes there is no response. I checked the entire circuit and found no shots or open wires. FUEL PUMP RELAY has been replaced, and it does the same thing. my car is burning gas like a V12 engine... help!!!! =]
could this be a bad fuel pump?
