1 - 15 of 15 Posts
04 NBC Turbo Tiptronic
Out of curiosity, how many people don't vent when refueling? Also, if I wanted to fill the tank, could I just let it pump 'till it shuts off or is there a possibility of spillage?
Go Sox!
I always vent because I want to get an accurate measurement of my miles per gallon. The pumps around here will automatically shut off for me with no spillage, but I always recommend keeping an eye on it because the diesel fuel can foam up, especially with no venting. Please keep in mind I am talking about the small fuel nozzles at the local gas stations, and all bets are off if you are using the large nozzles the truckers use.
180 Degrees out of faze
I think you just convered another, so new total is now 851.
Tell your mom I said hi
I've got a ritual for fueling. 6-8 ounces of Power Service first so it mixes good. Then fill up watching for foam. Foam has only been a problem when fueling at a truck stop with big nozzles. Then slowly vent 'til full. I don't vent during the heat of summer unless I'm on a trip as diesel can expand when hot and over flow.
Another question, when the ULSD comes here, would we need to do anything to the car? Will it affect the fuel milage?
I vent all summer, living here in VA. I Have never heard of a 1st hand experiance of fuel expanding and leaking out of a diesel....
I've never had it happen in a NB either. Have in a truck though. Preventing this is one of the reasons for the air space that we are defeating when we vent.
the only thing we had it leak out of is a steel tank in a truck. The tank set behind the bed in full sunlight. Being steel and sitting in the sun insted of plastic and in the shade may be the difference.
So this is the Y2K bug...
in the filler neck or "pipe" that you pump the fuel into, there is a small black button that when pressed down vents air into the filler neck, allowing more fuel to go into the tank/filler neck.
Diesel bubbles up. push the button, vent off the bubbles, add more fuel, drive farther between fill-ups!
Good-bye Curby...
do gas beetles have this, too?
Vent? What's a vent? ;)
I'm ventless, baby...............yeeeaaaaaah!
1 - 15 of 15 Posts
