1 - 14 of 14 Posts
VW Nerd
2012 VW Beetle 2.5
Okay, I think I blew a fuse for my stereo today - but the fuse card is very confusing. Does anyone know which fuse controls the stereo?
I scanned the card and attached it as a pdf. If anyone can tell me which one it might be, that'd be super. :)
Toad said:
Every aftermarket radio i've had has always had a fuse on back.
Every headunit period should have a fuse on the back. Pull it out and take a look. Even if, for some unknown reason, there isn't a fuse on the back of the HU... you're going to have to pull it to check all your connections anyway... 'cause, if it ain't a fuse, then the HU is either kuput, or isn't getting power.
BTW... here's a more complete fuse card. I made it to fold up and put in place of my factory fuse card. It's for my 2004 NBC... but it should be fairly universal.
i have the same problem on my 2002 1.8T (EU spec), the fuse card doesn't show the stereo symbol.... bummer... why do they do the symbol fuse card thing when it's not all on there??? my radio is the original VW factory gamma stereo system... there's no reason the stereo shouldn't be on the fuse card. #$%#[email protected]##@!#[email protected]#[email protected]#$#$.
i'll try 37/42... i think my stereo has the "monsoon" amplified speakers, which would make sense: 2 fuses, one 10amp for the head unit and the 25amps for the amplified speakers...
steinola: thnx for the detailed fuse card!!! i printed it and will put it in my NB!
Keep On Groovin' On
Fuse Panel Guide for RHD owners
Hi Guys,
I found this thread while working on my car and locating a blown fuse. The Card in the panel isn't that great and the diagram provided by Steinola was very useful. I've made some changes to it for Right-Hand-Drive (RHD) NB owners as our fuse panels (and numbers) are flipped/mirrored in our cars. The annoying thing is that the factory put a LHD card in our RHD vehicles too so you have to mirror everything on that to read it as well!:rolleyes:
I hope this is useful for other RHD owners and thanks again to Steinola for the original - it's a much better reference than the factory card :)
Radio fuse?????
Hi, guy,
My Beetle is 2006 1.6L (Australian version). I checked the fuse box on the driver's side after the radio was dead. But the fuse layout does not match
the diagram of the owner's manual shown as above. Here are the photos I just took for the fuse box. I want to know which one is the radio fuse (obviously, no #42 seen in the fuse box).:confused::confused::confused:
You have a 25 amp fuse in #42. It is the third slot up from the bottom on the left side. The bottom slot is empty, so it is the second fuse that is actually there.
Yes, that's it. Fuse #42 from the diagram in post #8 above. The post explains that the fuse panel is mirrored compared to the left drive version, but the diagram on the cover is not.
VoodooMaster
Fuse 41 is for the 12V outlets. The location in my 2010 bug is empty? WTF, the outlets work. Anybody have an idea why?
1 - 14 of 14 Posts
