New Beetle Accessories
The metal cable is seized up in the plastic sleeve. Time to replace the cable (around $30 for the part) or see if you can lube up the end and get it to work temporarily. This is an extremely common problem, especially this time of year.
An Air-Cooled Fan, Too!
Might it not be the switch, though?
I'm not disagreeing with your suggestion about the cable, but what bothers me is that there is no "quirky" sound anymore when I work the release button located near the bottom of the driver's side door...nothing, just silence. Therefore, that also leaves me to wonder whether the switch may have gone kaput? :confused:
Eine Kleine Panzer
Open the trunk, then remove the circular cut-out on the passenger side (it is towards the back near the tails). Once the cut-out has been pryed off, feel around for the cable and pull it to see if that unbinds the cable and opens the door.
You should at least hear a mechanical motor sound when you push the button. If not you may want to investigate the fuses and motor.
