Randomly every two months or so, when I shut the engine off, the same bell that warns the driver of low fuel, sounds off. I have no warning lights or codes. The engine runs fine. I just can't figure out why that bell goes off?
I know this is a bit of a stretch comparison but a friend of mine has a bad fuel pump in his Pontiac and randomly it will set the low fuel alarm off and the needle will drop to zero. So, maybe you should have your fuel pump checked and see if thats whats causing the alarm to go off.
On this last tank of gas the fuel guage was pretty erratic on the first 1/2 tank. I know how many miles the guage should read (roughly) for every 1/4 mark. Normally I go close to 150 miles on the first 1/4 tank then buy half tank its at 250 then by time the fuel light comes on I am at 350 miles. This last tank I was at 90 miles at the first quarter and only and only 200 at a half and then finished of at 360 miles at the fuel light.
It would be sad to see the pump go at only 72000 miles.
Basically what happens is the various systems shut down at various speeds. So every so often, the gas gauge shuts down quicker, the gauge hits low, the computer thinks the car is low in gas, and it beeps. Happens to most of us every so often.
I have a 2000 VW Beetle with a 1.8L Turbo. It has a manual transmission. I am having issues getting it to start.
When I turn the key to run I get dash lights and all accessories turn on. When I turn to start nothing happens. I replaced the starter lock relay. I tested the clutch relay it seemed...
Hi all, just found this forum.
I had to repo this vehicle yesterday . I got it back to the yard and found it had a broken key fob. I was able to start it though. It ran like crap and would barely idle. I put my OBD II scanner on it and found 9 codes... I cleared them without taking note of...
I replaced the timing belt and cylinder head on my 2003 convertible but when I tried to start the car it turned over a few times but wouldn't start. When I tried again it was just dragging as if I had a dead battery. tried 3 different batteries but it would barely turn over. Any idea where I...
My New Beetle 1.8T made its way back home! Resurrected from an almost certain junkyard death, it has been restored back to life over the last 3 months. Please enjoy a few pictures of it’s current state and stay tuned for more development as the build continues! PS I’ve cc’d in a few vids from my...
Does anyone know who sells the 4 Wire Cooling Fan Drivers side. I know the dealer but I cannot afford those prices. I have seen on Ebay the 3 wire sells for $99.00 with shipping but a 4 wire is extremely expensive. I dont even know why I have a 4 wire one. maybe cause of the Turbo???
Any...
