Got my wife's 02 Turbo with 130000 for a song. Turns out the seller may have been happier to get rid of it than we were to find a bargain. It ran fine for about 2 weeks after we bought it and then one fault code after another over the last 2 years.
So far have put in new coils and plugs, have replaced the throttle body, replaced plastic hoses that were cracked and throwing secondary air intake codes. And, taken out crappy wiring for after market radio. So, obviously a less competent DIYer had this previously.
But, now I have THREE major issues that may or may not be related:
1) The car will run fine cold, sometimes for a few miles sometimes 10, but then it will sputter and die. The interior lights stay on but I can't restart the car. Nothing happens. But, if I come back to it 24 hours later, it will crank presuming it has enough juice. Which leads me to...
2) I can't keep the battery charged. I've had it checked twice and charged it overnight myself. Charged to 13.68 amps and while sitting outside the car the battery decharged slowly to 12.68 over a week. I charged it again and put it back in the car but pulled out all the likely fuses with the intention of trying to pinpoint which one the causing the parasitic drain. I was in the process when I needed to drive it. It ran okay but...
3) Check engine light came on and I noticed the car wasn't starting in 1st gear but 2nd. I could force it into 1st by shifting there but it wouldn't to into 1st on it's own. It started losing power and stalled. Would not restart. 24 hours later it restarted and I drove it home where it sits now and doesn't have enough power to crank. The battery reading is now 11.80!!
Present codes are:
0725 - Engine speed input circuit
1780 - DTC definition not found!
1850 - " "
and the 0411 ghost which I've been chasing since I bought the damn thing. The hose I fixed is fine.
My first guess is that I have a faulty crankshaft sensor, but I can't figure out why the hell the battery keeps dying. The ABS also started blinking so I'm wondering if given all these problems if perhaps I just need a new ECM.
Any suggestions, or it's definitely not that, or try this would be appreciated.
Present codes are:
1850 - " "
