Alright, I know that the early NBs had 4" of ground clearance (as per the specs in both the Bentley and the owners manual). How about the '06+ cars? Got a question about it over on the 'Tex.
Please! I've been asked for this info and really would like to have it. Its listed in the specifications in the owners manual as well as the Bentley. Specifically, the question was referencing an '08, but I would imagine all '06+ cars (hardtop) have the same clearance.
The little googling I did turned up 4.6", but someone else said that its 5.6". Just wanting the info.
Yesterday my SRS/Airbag light came on. I figured it was the wires in the drivers seat because the car wasn't able to sense when I wasn't buckled in. Then I realized the button to open the boot wasn't working. This morning, the ABS light and the ASR light came on. I checked the brakes to make...
1998 Beetle started draining battery when clutch not engaged and/or when sitting in idle/neutral. Mechanic says bad alternator. Weather changed and it’s cold where I’m at. Battery no longer drains and battery charger shows battery full. This doesn’t make sense since the problem should get worse...
Hi—my 1999 2.0 gas GLS has a failure in the 5-speed manual transmission. It’s making an awful racket when I turn right and 2 shops tracked it to the differential. It’s $1,500 to install a used transmission ($650 part) plus possibly another $450 to replace the clutch plate, so about $2000. Is it...
Hello if anyone can help ? I have an ‘05 beetle convertible with just 50k miles as I was driving the airbag light went on. How can I repair/ fix it? I’m a little paranoid about driving it..
Hello everyone, I'm new to the whole New Beetle family I recently bought a used 2000 2.0LT GLS beetle and I noticed it was burning oil so I did an oil change to it and it worked amazingly after and no smoke at all, it was used about 6 times and then it sat for about a week and half not being...
