How-To by BugMod.com
Photo's and Info by: DOOODLE Written by: NETBEETLE
New Beetle 98-03 Gauge Face Swap
In this article, we're going to cover the process of swapping the instrument cluster gauge face. John chose to install an electro-luminescent face, but this article will cover most other installs as well. One important note before we start: DO NOT INSERT YOUR KEY INTO THE IGNITION UNTIL COMPLETED WITH THE PROCEDURE! The only setting that will be lost is the Trip Odometer reading - write the number down if you need it.
Tools needed for this Mod:
T-20 TORX
Small Flathead Screwdriver
Small Pliers
Approximately 1-hour labor time
T-20 TORX
Small Pliers
