HELP!!! LOL
2000 GLS 2.0 Automatic
Symptoms:
On a cold start, I have to crank it for about 5 seconds, 3-4 times before it will finally start.
Once started, I have to let it warm up a bit or it will stall.
Even once warmed up, I have to baby the gas or the car will stumble and stall or lay over.
Even at highway speed, if I push on the gas too far or fast, she will nose over.
When it rains or is damp, she will buck and stall....I assume that is the coil pack?
I changed out the fuel filter, but that did not help. Air filter is clean.
I took it for inspection....I knew it would fail because the CEL was on, but wanted them to run the scan anyway.
Here are the fault codes:
PO302: Cylinder 2 Misfire Detected
PO303: Cylinder 3 Misfire Detected
PO300: Random/Muliple Cylinder Misfire Detected
PO112: Intake Air Temperature Circuit Low Input
PO102: Mass or Volume Air Flow Circuit Low Input
Where do I start???? Your help is greatly appreciated!!!
Symptoms:
