You can look up the codes here: ross tech wiki
Ross-Tech Wiki
Code P0725 / P0335 / P0340 - Crankshaft Positioning Sensor:
is a very good possibility your CPS/speed sensor is dying and will cause a no start or hard start condition.
16804/P0420/001056 - Ross-Tech Wiki
16706/P0322/000802 - Ross-Tech Wiki
P0134 O2 Sensor Sensor Circuit No Activity (02 sensor maybe failing or wiring issue)
16501/P0117 - Ross-Tech Wiki (coolant temp sensor maybe dying; also can cause hard start issue)
17524/P1116/004374 - Ross-Tech Wiki (pre cat 02 sensor bad/wiring problem)
16795/P0411/001041 - Ross-Tech Wiki (check secondary air injection for problems)
Ross-Tech Wiki
