Send Money
Probably be a bit more useful if you stated your model and year. (05 vert, 01 sedan etc.)
They are not all the same
These are the steps on how to access the hazard flasher switch..
1. Take a credit card and slip it between the top of the switch and the dash. Use the credit card as a lever to pop off the top of the switch. Should come off real easily. Credit card is prefect since it won't scratch the dash.
2. take a pair of pliers and grab the raised plastic rim that the top snaps on. Pull the switch out of the slot. Wires are attached by a terminal with clips. Pull the two sections apart and insert the new switch.
Doubt they are still here to even tell you if you look at the date of the OP. Our lovely PartsBin spammer bumped a 5 year old thread...
