Is there a how too anywhere for an AQY head gasket ? , mine seeps a little oil but appears to be ok apart from that.
Are you sure its the head gasket and not just the valve cover gasket?
compression ok
no oil in water but does seem to pushing oil out between gasket and head.
cleaned whole engine with degreaser and doesnt seem to coming from cam cover
If you think; you have a head gasket issue, confirm by doing a compression or leak down test.
That issue has become a bit of a moot point as the water pump looks to have died , so water pump/cam belt/tensioner being done on wednesday.
