First Time Away From GM
i did a search, nothing showed up. im looking for a diy on head removal. 1999 with 2.0
thank you
tom
Gees!
Well, I just typed a rather long detailed piece of helpful info....and as usual, when I hit Submit, lost it!:mad:
By the book, which may include some information a "DIY" or "How-to" may not...
M.
head removal help
To you people who removed the head. where did you remove the exhaust? manifold or did you leave manifold on ? how do you remove the shield to access the top bolts? Thanks
I disconnected the down pipe from the exhaust manifold. You can actually reach all four bolts from topside. The head, exhaust manifold and shield all come out as a unit.
I suppose that if you really had to, you could remove the exhaust manifold by first removing the shield (four allen-head bolts, if I recall, across the top of the shield). This would allow you access to the exhaust manifold bolts.
