Make sure the light is seated correctly in the holder. If it does not make good contact with the connector all part of the lights don't work correctly( low beam, high beam or DRL) depending on which connectors have good contact.
Also make sure the connector is tight in the "bucket"assembly, they can get knocked loose or some of the clips break and the connector moves so the light does'nt want to make good contact.
The assembly with the release arm is a replaceable unit.
Volkswagen New Beetle 1.8T Lighting Headlights - ECS Tuning
